View RMON control tables to see the data source for both network layer and application layer host statistics.
RMON2 can count application packets received on a platform, even if the application is not enabled or supported, before dropping them.
Switch:1# show rmon ctl-table
Rmon Control Table
Protocol Directory Table
IDX PROTOCOL ADDRMAPCFG HOSTCFG MATRIXCFG OWNER
1 IP SUPPORTED SUPPORTED NOT SUPPORTED Switch-1
2 TCP SUPPORTED SUPPORTED NOT SUPPORTED Switch-1
3 UDP SUPPORTED SUPPORTED NOT SUPPORTED Switch-1
4 FTP SUPPORTED SUPPORTED NOT SUPPORTED Switch-1
5 SSH SUPPORTED SUPPORTED NOT SUPPORTED Switch-1
6 TELNET SUPPORTED SUPPORTED NOT SUPPORTED Switch-1
7 HTTP SUPPORTED SUPPORTED NOT SUPPORTED Switch-1
8 RLOGIN SUPPORTED SUPPORTED NOT SUPPORTED Switch-1
9 TFTP SUPPORTED SUPPORTED NOT SUPPORTED Switch-1
10 SNMP SUPPORTED SUPPORTED NOT SUPPORTED Switch-1
11 HTTPS SUPPORTED SUPPORTED NOT SUPPORTED Switch-1
Protocol Distribution Control Table
IDX DATASOURCE DROPFRAMES CREATETIME OWNER
1 0.0.0.0 0 09/22/15 19:29:13 Switch-1
Address Map Control Table
IDX DATASOURCE DROPFRAMES OWNER
1 0.0.0.0 0 Switch-1
Host Control Table
IDX DATASOURCE NHDROPFRAMES AHDROPFRAMES OWNER
1 0.0.0.0 0 0 Switch-1
